I bought a 1992 TRX200D that is missing ignition. Also indicator lights were unplugged. I have 2 black/Red wires in the same outlet in the harness. Are all black wires grounds. I have attached pics. The color codes on most are self explanatory but there are a few that I'm not sure.. I don't like to guess without seeking help/info from someone more knowledgeable. Ok so I out all the wires together just to see what's what. And I'm the last pic you see that There are 2 extra wires one is green/red the other is blue/red. I know one of the two will go to the ignition . What does the other one go to ?
green is your neutral light, blue is your reverse light :). you should get your hands on the service manual, and read up on the schematics for the wiring :).
After ignition install
My ignition came in so after i hooked it up I looked at the wiring again after reading your post and the wire colors are different on my model then suggested. ive attached 3 new pics of the indicator lights wiring also that extra damn blue wire that i have hanging around.. that drives me nuts :( i havent found any where i can plug it in.
BTW i plugged in the ignition and everything came on. it has a bad solenoid so ive ordered that now. will be in tomorrow morning.
I gave you the wire colors for the neutral and reverse light, not the ignition switch..lol.
