1 - 9 of 9 Posts
I have the filters for the TRX250x the 200 only have a screen B:UT
waht oil do i use in the machines?
i've seen people talking about useing just 15-40 oil
and som kind of energy saving oil
what should i use
Use a 10w-40 motorcycle or atv oil mean for wet clutches. The cheapest I have seen is by Valvoline. You can get it at AutoZone or Advance Auto for about $4 a quart. Your 200 will only take about a quart and the 250x will be around 2 quarts.
Rob
Like dr.feelgood said the oil has to be designed for a wet clutch. I would suggest any oil brand besides Castrol. Unless you want to give your hard earned money to BP (BP owns Castrol). lol
I ran the mobile one synthetic for a while then the price went up to the same as amsoil and i changed over to amsoil because i get a good deal on it from a local shop. Amsoil seems to hold up a little better over time.
Honda GN4 is the recommended oil, but any oil designed for wet clutches should be fine.
I recommend AMSOIL Formula 4-Stroke Synthetic. It withstands the high temperatures of ATV's - resisting heat and thermal breakdown, keeps engines clean and controls oil thickening to provide excellent operating efficiency, and is also wet clutch compatible. I run this in both my 250r and 400ex.
Let me know if you would like a quote.
Read More Here...
1 - 9 of 9 Posts
