This thing must be possessed...as there can be no other logical solution.
I have a new CDI box in it
A new coil
A new Ricky Stator -Stator and pickup
A new wiring harness
AND A NEW PLUG
Still no spark....but the stator is lighting the lights as you pull it over.
Now before anyone says the switches---- they are unhooked at the wiring harness...
The ground I have moved from the frame to the engine without any luck
The Neutral safety switch has been disconnected.
Could it possibly be the FLYWHEEL?? DO THEY GO BAD?? WHAT CAN GO BAD WITH A FLYWHEEL?? When I first removed it I gave it some heat and a small bit of black substance came out of a couple of the holes...not much though
HHHHHHEEEEEEEEEEELLLLLLLLLLLLLPPPP!
:funnypolaris:
A new coil
AND A NEW PLUG
:funnypolaris:
