I think you should go down on the clip on the needle.
I was not thinking right! I thought if you moved the clip down it would hold the needle open more. Letting in more fuel.if i went down on the needle it would only get worse. it started off on the bottom setting of the needle and it got better when i went up.
I was getting a strong spark. is the accelerator pump part of the carb?
The accelerator pump would cause it to sputter but only for a min but then it should rev back up. I Had a dirtbike that didnt have a pump and if you would just throw it wide open it would sputter for a second then take off. :icon_question:my diaphram does have some rust on the steel part of it, the rubber seems in good condition
