it's an 06. I've replaced coil and stator, and checked kill switch on handle bar, they key switch has 1 volt going to engine stop wire.
no power to the coil.
I had the same problem with my daughers 06 trx450er once after reasembling it over the winter and the problem was the I had the temp plug on the coil and the coil plug on the temp probe. So just make sure those are correct.
Make sure you are not in Reverse also or the sawitch isn't unplugged. trying to start in reverse won't happen there is no spark, safety issue unless you by-pass it
