2007 TRX 420 4X4 Display is flashing a code and I sure would like to know what it is. Where it indicates the gear it is in -it flashes 2 long and 2 short. It has also quit shifting with the electric shift. I have to get down to front of the transmission with a wrench and shift manually. The flashing display and electric shift not working happened for unknow reason. There is no sound when I try to use the electric shift.
Does anyone know what the code is?
Or, how to wire it to work around the sensors?
Or, how expensive it would be to put or have a manual foot shift put in?
Any help would be appreciated.
DeKalb-Born
Are you getting power down to the shift motor?
I'm not sure. I did find something had hit the blank angle sensor and broke the wiring connector. We've been under storms the last few days and haven't had time to do much checking it out. I did go ahead and disconnect the blank angle sensor and still get the same code.
Another question someone might be able to answer for me is on the bank angle sensor and wiring (part # 35161-HP5-601) - where or what does the other end of the wiring plug into? I'm thinking about just ordering that (if I can't bypass it) and put it in. Any and all help appreciated.
