hello can any one help me i got a trx 350 and im pulling my hair out at the moment the netrel light will come on some times and most times not and wen the light goes out it will not start at all not even pull starting it with the rope ive tried all i know and i cant get to the botom of the problem any help on this will be great thanks
is there a sending unit that could be bad maybe a wire lose. Mmmm? there is a guy on another forum that i talk to that may make some good suggestions. the forum is www.atv-forum.com. he is pretty good at these types of problems. Sorry for recommending another forum but he may know. HOpe you get some luck some where. by the way his name is saber6. he is now apart of this forum . good luck.
Your problem is most likely caused by the neutral safety switch. The switch is in circuit with the ignition so the machine can not be started in gear. The switch should be on the side or top of the crankcase with two wires coming out of it.What year is your machine?
