Question regarding installing the large starter gear and clutched flywheel. I am in the process of rebuilding the engine for a 2000 Honda 400ex and am to the point where I am putting the flywheel back on. When placed on the bench with the large starter gear installed in the flywheel the gear only rotates one way as it should smoothly. When installed on the crankshaft and after I tighten the bolt down the gear will not rotate either way and is jammed up. It should rotate backwards smoothly and lock up during starting to crank the engine over. Why would the gear be jammed up once the bolt is torqued down?
