I've used a lot of them $40 piston rings gasket and everything needed off eBay and never had a problem, even bought a kit that included a whole new jug and everything else for $80'with good results. I personally like Namura, but they run about double, $80 for the piston, rings, and gaskets. But when I run across so many 350 Ranchers that smoke the $40 kit seems the way to go.
2006 Rancher 350? Or 400?I'm having to rebuild my top end. I was looking for advice on wether to buy all Honda parts or buy one of the top end rebuild kits I see every where online. Anyone have any experience with some of the kits you can get online?
2006 350 4x4[/QUOTE]2006 Rancher 350? Or 400?
Don't forget to replace valve seals while you have the head off.... age and heat gets to them.I'm guessing the 350 ranchers have an issue with smoking?? Had mine forever and it just started smoking recently
Welllll, on the one hand, I agree with you, which is why I sent my 350 OEM cylinder off and had it bored .50 over with a new piston.ive seen those cheap kits also available for grizzly/rhino 660 motors.
they're stupid cheap. $230 for piston, cylinder and camshaft.
i'd be very leery if I were keeping the machine for any extended period of time.....
I was hoping it might work for him, but when I found pea gravel in the bottom end I figured the cylinder might be a little too worn for just a set of rings to fix it.I've gotten by many times with just a good honing using my Flex-Hone and a $20 set of Namura Rings, on several machines that I've kept a while, and others that sold 2 days later. My dad who has taught me everything I know (except this forums lol) (I love them), and he worked in a Tractor shop many yrs, he's taught me the in and outs of that's acceptable to reuse and such, I would probably never have succeeded at this for a living without his knowledge.
