have you tried going to your local honda dealer...and asking them if you can borrow thiers ?..if not..then do what i did..take a few old screw drivers..wedge them between and under the flywheel starter gear and case..spread them out around the starter gear..there is a opening in the starter gear where you can do this..now..screw in the starter pull start bolt..put a socket on it..( use an old one if you have it )..screw it in a good ways..no..it won't bottom out..just get it in about half ways...make sure your screw drivers are wedged good..now..whack the socket a few times..keep knocking the screw drivers in alittle at a time..keep hitting the socket with a hammer..that flywheel will pop off..done it on mine anyway.I need to know if there is anybody that has a flywheel puller and a clutch puller for a 2006 rancher 350 that they will sell, rent me, lend me, let me have, borrow, or tell me where I can get them. I'm in desperate need. Thanks
