Just picked up an 86 fourtrax 350 4x4. It's been sitting for a while. Previous owner told me it ran when he parked it, but it was backfiring and thinks the valves just need adjusted.
So, I've put new battery, new oil and filter, new spark plug.
When I hold the plug to the head, I get spark. It's not a bright spark like a car would get, but there is a spark I can see. Should it be a bright spark? Also what should the gap be? It's at .025
Next is fuel delivery, I'm getting fuel to the carb b/c when I take the plug out of the bottom of the bowl, gas comes out. But I'm not sure if it's making it into the motor. Is there a way I can tell? I was trying to start it with the airbox and filter off and I could see a couple drops of gas shoot out of the carb.
Will it crank in any gear but neutral?
Can I use automotive gear oil for the differentials?
I've got it cranking, but won't start. So, that's why I'm wondering if I've got enough spark and the gap.
Thanks for the help. I'm sure I'll have more as I get deeper into this thing.
