1 - 17 of 17 Posts
Just wanted opinions.... For you fellas who longgggg (im talking over a year +) store carbureted hondas and don't have a sorce for ethanol free gas ...... Do you idol the machine till it dies, OR completely drain the carb bowl ?
Heck while we're @ it opinion on petcock settings ......lol :devil
I would completely drain the bowl that way absolutely no fuel is sitting in the bottom of that carb.
And what do you mean by petcock settings? I run mine on- ON then when the bikes stutters I flip it too RES
When I live in Illinois there was no ethanol free, in my lawnmowers I would drain tank and carburator, they would always start but that was only about 5 months though. Maybe for that long I would drain everything and go to like home Depot and get a gallon trufuel gas they have in 4 cycle now and pour that in. It's suppose to be good for like 2 years opened and 5 years unopened. It's 20 bucks a gallon but for storing it would be it.
if it was me, I would one fill tank with fresh TREATED fuel
run treated fuel for a good 5 minutes and then shut motor off and LEAVE as is
BUT Then when going to re start atv after a yr of sitting, I would drain everything, pull and even clean carb
my reason is, there are seals and gaskets that if you leave them sit DRY they can fail, faster IMO then if full of fluids!
NOW< if you really WANTED to use NON ethanol fuel, like said above, LOWE"s HOME DEPOT and like places sell it, in a metal can,, would NOT be cheap to buy to fill the tank, but you should b able to get ti there in with where they have lawn mowers and chain saws!
I would also be plugging up the exhaust with an exhaust plug, adding some moth balls to air box, and pulling battery out of atv and kept indoors on a tender
I MIGHT even pull spark plug and spray down hole with some WD 40 or like oil, to help make sure things there stay free!
also I think I would jack atv up off the ground to relieve tires from getting flat spots opt cracks in side walls!
I would not ever leave ethanol laced fuel in any fuel can, fuel tank, carb & lines, whatever... for more than 30 days. I'd dump it into my burning barrel and toss a match in on it.
As far as long term storage goes? If its gonna sit through a winter I treat the fuel then empty everything out completely. Change the motor oil, then run the carb dry until the motor dies while the choke and throttle are held open. Then either open the float bowl drain to get those last few drops out, or sometimes I'll take the carb off for indoor storage. Either plug the exhaust as mrbb mentioned, or take it off the bike for indoor storage. Replace/flush the brake fluid out 100% every fall and spring... change oil in diffs. Take the spark plug out and add 1/2 oz of fogging oil or synthetic two-stroke oil to the cylinder. Crank it over a few times, put the plug back in then roll it up onto TDC on the compression stroke. Take the battery and air filter indoors, plug those holes you've left open and wait until April showers stop bringing out the snow plows. :)
Ethanol is optional around here so I don't have to deal with that problem with my own stuff.
someone posted a link, that list places that still sell real gas. i got three, between 12-20 miles, from me. it posted non ethanol gas by states.
Tru-fuel works great.
If this quad sits in unheated shed i would not leave a tank empty due to condensation = rust. Heated building with lower humidity is better.
You could oil fog it–lots of options and methods from car collectors.
Maybe remove the tank and oil fog it and carb too.
somewhere, between 2016 to now, was another link.
i might have to find my wood-chucking forums, if i havent lost my sign in page over the year's. i feel sure the link was here also.
best check it out on my older PC, before i switch out motherboards, while i got the chance. the small hard drive in it, dun like, when you switch motherboards. its XP home edition, from 2002. still has info on it. i swapped back an forth so many time's, it got aggravated.
not to say i'm aggravating or confusing :grin
Oh and petcock settings...
On 86-93 trx350 the reserve setting intake screen sits at the bottom if the tank BUT can’t completely drain the tank. You have to remove the tank drain bolt and try to get the quad level to drain the tank. And then you have to roll it back and forth. That’s as aggravating as having to swap hard drives;)
I do run my other petcocks on reserve settings occasionally to try and access any condensation. I run my old Softail on reserve quite often cuz it gets turrible mileage like 160 miles per tank and she surprised me last Tuesday when she got 129 and i was a long ways from my usual ethanol-free station :0
Discussion Starter · #11 ·
Thanks for the imput! fellas! Xp ... I agree drain the carb bowl completely , retro i agreed to a point,
Goober exactly
The tru-fuel sounds expensive @ $20 a gallon ... That's the cost oft it here @ my local ace hardware , and ya i keep my tanks topped off and treated with (die hard believers in) >>stabil 360 marine grade. As for petcock settings ... As a rule of thumb .... I don't use mine (hardly ever)
As for 100% ethanol free gas ..... Around here... This isn't any... People clame ethanol free, but I've been told under certain percentages the CLAME is, it's eth free.... I know all the distributors around, and i have been told there is NO 100% ethenal free gas, except turbo blue ..... Racing gas....
Reactions: misterclean59
Forgot this ....
As a rule of thumb .... I don't use mine on reserve(hardly ever)
considering how much the fuel gets shook up, maybe it dont matter. some of us dont pay attention to the fuel gauge, that is hard to see. if we were looking any way. :grin
Discussion Starter · #14 ·
For daily runners ? Ya maybe, but Id still avoid using reserve and You missed the MAIN point, she wont be used! AT ALL!!
I again think this is over thinking deal
I ride snowmobiles and have for 30+ yrs,
Us Snowmobile's park our sleds for almost yr almost every YR we have them
we simply treat fuel and park em , shut pecock's to OFF, and that's about it for fuel system!
the carb'd ones MANY simply clean the carb at the beginning of every season and DONE deal, snow comes and we ride away!
I would NEVER drain a tank to empty, its actually rather common practice with snowmobile to NOT drain tanks dry as again, you end up with more issue's than leaving fuel in them!
this again is done every yr and sleds here sit from say March to following dec every yr tens of thousands of them, and this works just fine
Discussion Starter · #16 ·
YES! I agree (keep tanks full) all three of my Hondas a mint 2000, 300 fwd 97 300 fwd (aka lot lizard) and the 86 350 tank are dry stoed in a non heated shop.
Ted this shows how even shaken up gas will settle quickly .... Treated gas maybe not so much... I'm not taking the chance on using reserve! You almost never know what the gas you pump in is loaded with!
that snot color, defiantly is gas with water. maybe to heavy to get shook up. only a way to drain it from the gas tank..
my gas tank, when it got, not running on reserve, was still a lot left in the tank. more gas then you would think. it wasnt snot stuff, still hard to drain.
i took the petcock out, then put an old t-shirt in the bottom, to soak the gas out. it worked like a wick.
now,, to get this snot out, without taking the gas tank off. Hard to see, where that snot/gas settles.
1 - 17 of 17 Posts
