1 - 16 of 16 Posts
Hello everybody ,
Im new to this site and i have a question . I recently rebuilt my 85 200sx trx with new pistons rings and and to let you know i broke my coil pull starter so i have to push it to start it before i did the rebuild on the rrings i could push it and it would jump start and now when i try to push start it the tires spin but i checked the piston and it doesnt move . i adjusted the clutch and if i put too much on it the tires wont move at all. but when i put it to the factory setting they move but the piston again wont move so i took the clutch side cover off and i can see the clutch move when i move the wheels and then it stops moving and then pops backwards and keeps doin this while im spinning the wheels. also when i turn the flywheel wit my hand the piston moves so i know its not a stuck piston can sumbody please help me figure out what the problem is
It sounds like you may have sheard a key on the input shaft in the tranny...
Welcome to the forums.
DID you tear down the whole engine tranny and all? if so you may have forgot to time the gears
Discussion Starter · #13 ·
no i only took apart the top end down to the top of the crankcase i only replace the oil and compression rings and when i put it back togetha i timed it , i was looking at the clutch pack and it might be slipping could that be it?
Yeah it's possible. what kind of oil did you put back in it?
1 - 16 of 16 Posts
