Hi every.
I currently own an 1999 Foreman 450 ES.
The rims are ITP 12" rims with proper Honda offset. The tires are 28" Outlaws 10" and 12.5" wide. No lift kit.
I bought the bike setup like that, and the fronts rub the fender in reverse but otherwise handles the tires fine.
The rear ties have about 3/4 tread left and the fronts are at 1/4 tread and the flat part of the tire touches ground.
I don't go in the kinda mud you see Ostacruiser in, etc. I mostly stick on trails, gravel, sand, light mud. I do drive swamp and mud occasional.
My brother has a Foreman 500 with 27" Swamplites, and I need to be able to follow him as much as possible.
The tire choices I am currently looking at are the following:
ITP Mudlite XL 26", 9-12, 11-12
Interco Swamplites in 27"
Interco Reptiles in 27", 9-12, 11-12
I heard reptiles are small for the size, but I don't want bigger diameter then 27" Swamplites (I know how they look)
The other option I am looking into, but Highlifter customer support isn't responding to my emails is to purchase 2 replacement tires. I am wondering if I could put an Outlaw MST 28" 9.5x12 without messing up my 4x4 due to different tire styles
Different tire styles will not mess up anything in your 4x4 so you would be fine to put mst's on the front
Outlaw MST, Mud Bug, 'Zilla, Mega Meyhem, Silverback X-Lite would all be good choices. I don't really like Swamp Lites, I don't find they perform as well as Mud Bugs and their trail manners are no better either. They also seem to wear faster. The Reptiles are a little more trail and a little less mud.
Here is a pic of my old 450S, I ran 27" Mug Bugs on it....
Hi every.
Mudlites wear well and get around great, I used to run vampires but my buddy ran 27 bearclaws on his Rubicon and could hang with me on most all stuff and rode a lot better. Interco tires always wear fast, they use a soft rubber but they hook up much better. Everything is a trade off,mudlite xtr radials maybe
