Hi all,
I am getting ready to order a new set of tires and would like to get your input on size. I am going from 26 gators to 27 outlaws. Should I go narrower in the front or same size all the way around? I will mainly be playing in deep mud and water. I'm not too worried about being comfy on the trail. And if I do go same size should it be 9.5's or the 12's? Thanks for any info.
Welcome to the forums. If your not to worried about comfort the go for it. I would stay the same size front and rear but only if there is no interference in the front? Suspension ect.
Welcome, If your quad is 4x4 and you ride trails and on some hard pack then you will want to run a little less air pressure in the front tires if you get the same size tire all around because the front are a little shorter from thr factory. Otherwise you will be fine.
Oh yeah I run 9.5 all around on my 300 when I had the outlaws. But they are a (mud) tire and dont ride very well anyplace else.
Dont know why I hadnt done this already but I went outside and looked at the tires I have. 12's on the back and 10''s on the front so 1's all the way round should be fine.
