1 - 10 of 10 Posts
New wheel?
Sent from my SM-G930T using Tapatalk
I don't think you need a new wheel, LOL
But wheel damage can cause leaks, be it a bent spot, damaged from trails(rocks and like), or could be a BAD tire, that has tire damage to it where it needs to seal
WHO mounted the tire, YOU or a shop?
to rule out the tire you can, mark tire where its leaking now, then deflate it, and spin it on wheel and re inflate and see if it still leaks in same spot on tire,
OR wheel
if same spot on tire, then its the tire that has damage
if the wheel, then the wheel has damage, if steel wheels, they can be bent back pretty easy and be good to go again
if aluminum?? well you might be able to smooth out the area to get a better seal, but if damaged enough and or cracks, its time for a new wheel!
Cleaned the rim with a grinder. Mounted it myself. Old tire had trouble too staying inflated. May be the rim but it looks ok
maybe you have too ruff a finish from the grinder?
but even so, if the wheel was out of round from a bend, grinder or not, unless you made it back to true round, it can still be the issue here, of a bend in the wheel, all the more so if you say it leaked before!
are the wheels steel or aluminum ??
KY
I changed my tire and could not get the bead to seal and noticed it was not completely seated. I tried dish soap and 40psi 3 times with no luck. then I used KY jelly ( really slippery ) and it sealed right up. No Leaks
1 - 10 of 10 Posts
