i have to change the timing chain on a 92 trx 300 fourtrax how do i get the timing chain out without tearing down the whole motor i cant find a masterlink or anything on it its got to much slack in it is the problem, i got another oner thats just parts i was goin to take the chain out of and swap
You will have to pull the side cover off the motor, the flywheel off and work it out through the bottom, but i would put a new chain and a tensioner and guides in at this time would not put used timimg chain back in it will save you a lot of trouble later.
