Cylinder sleeve is hosed on my quad.
Crack that goes up the cylinder wall to about 3mm form the top, 3/4 the way around the top and back down. Total loss on the sleeve and the rings. Piston head looks ok though.
Here is my problem. I can go two ways with this to fix it.
1) Keep it a 426. There are rumors that this is more reliable with the standard 10mm head bolts (or more reliable all around). I need to buy a 400 sleeve, have it pressed in and ground down to the 88mm spec. That costs about 275 where I live (100$ for the standard 400ex sleeve, 100$ to press it in and the old one out, 75$ for the grind from 400 to 426).
(side note, the piston head "LOOKS" ok. Is it possible to be warped or damage in a fashion that I can not see?)
Est total = 275$
2) Go with a 440 kit. There is one from DTM Powersports on their ebay store. It's out of stock untill this Saturday. Link here to the 440 from DTM.
Comes with Jug, piston, rings, gaskets. No cost to press in a new sleeve, just a flat 350$ for the kit. The one thing I don't have are the 12mm bolts for the head (the HD head bolts). There are rumors that I'll blow head gaskets left and right without the HD bolts.
Est total = 350$
Extra for HD bolts = 100$ (50 for bolts, 50 for install)
I've been told if I can get the 10mm to 40lbs-ish with some good heat treated lock tight then I should be ok with the 10mm head bolts. So I might not need to spend that extra 100$.
I already have the SPAC 4inch fan mod for my oil cooler, so I'm good on the heat problems that are inherent for the 440's.
I want reliability. This is a trail machine, but will see open fields/backroads and I LOVE jumps. I'll be doing some cross country with her, so I don't wanna be screwed out in the country somewhere.
At this point, I'm at in impass. I see it being cheaper for the 426 kit, and that was already on her anyway. I hear of 440 problems with the head gaskets and the 10mm stock bolts. So I'm leaning to staying with the 426.
Est total = 275$
Est total = 350$
