where is the "t" mark and "indicator" mark located??? on the cam shaft...
The "T" mark is on the flywheel. Take the small plug out of the left side cover and the indicator is on the crankcase in the edge of the hole. Just look back in the hole and you will see the "T" mark on the edge of the flywheel. There's also a "F" mark on the flywheel, but you want to line the "T" mark up.
Reactions: nickandnicole250x
can you find a pic for me?
The picture below shows the plugs for the 2wd and the 4wd both. The red circles show the plug you need to take out to see the "T" mark on the flywheel. The yellow circles show the plugs that need to come out to turn the flywheel. The bottom picture shows what the "T" mark should look like when you're looking back in the hole and the mark is lined up.
you know everything about hondas dont you???lol jk thanks so much...
No, not everything, just what I've picked up over the years by working on them. LOL. You're welcome.
