I have a question about rims for my kids TRX125. I came across a great free set of 10 in tires from a friend of mine the other day. I know that my kids TRX125 have 8 inch rims. I was wondering if I upped one of them to 10 inch is there a rim that will fit on the hubs of the 125? I was thinking that maybe a 250 fourtrax? or 200sx? rims would work if I found a used set? Any help would be greatly appreciated - Jack
250 Fourtrax have a 4x132 pcd in the front on 1985 machines and 4x110 for 86 & 87, the rears are all 4x110 pcd. I’m not sure on the 200sx. If your 125 is 4x110 all round there’s nothing stopping you using 11” or 12” rims. Just remember, the bigger the tyre diameter the bigger loss of power you will get, I would advise going no bigger than 2” from stock size in overall tyre diameter.
I don’t know of any later models being those sizes. Maybe you could search eBay for Chinese ATV wheels, they come in odd pcd sizes.
Well for the front, the 4/85 is used on 4 corners of the TRX90 so that you've already got 10" rim choices available: https://www.motosport.com/itp-a6-mini-quad-wheel
For the rear, with the 4/130 pattern, that is the one people run into issues with (same as 85 trx250 front pattern). You could try the stock from rims from one of those with the offset flipped. Or to get yourself to a modern 4/85 or 4/110 pattern on the rear, try a set of these: http://diamondjcustoms.com/wheel-conversions/front-wheels-universal-conversion-kit.html
You could use them per the instructions depending on the rims you put on the rear, or use them like I did: http://www.hondaatvforums.net/forum...rx250-utility-bolt-pattern-6.html#post1216986
Or buy a set of these for the rear and use 4/110 rims: https://www.ebay.com/itm/Wheel-Adap...ug-110-Spacers-4x130-4x110-1-25-/391145649211
Reactions: SamUK
