I got myself a 05 Honda rancher 400 last Friday.
Needs new tires and could use wheels.
I understand stock is 2+5. I have a chance to get a great deal that came off a new Grizzly700. Which I understand is 5+2.
They are both 4/110. So in short. Can I use the wheels that 5+2 on my rancher. Or will I need to move the tires to the old wheels?
Well, if your stock is 2+5 and what your wanting to get is 5+2, they will never work. The 5 is the backspace and is wat to deep and will rub on the frame or God knows what else. If you can turn them around, you'll be fine. I'm actually fixing to post about some wheels for my 300FW, and have a question or two myself. I've been doing some research and studying, and trying to find aftermarket wheels with the correct offset for the rears without having to run an inch and a half or two inch spacer is my issue, having those just adds a ton of added stress on rear end parts, axles, ring and pinion and on and on, so definitely don't want to sacrifice performance for the sake of a little bling lol, so needless to say, I'm having a rough time finding what I need, or if it even exists, but I'm fixing to post and find out!
ITP do a great looking steel wheel with stock offset and a plus 1 option.
