and there are folks that say they get 30 MPG's in there trucks
does it make it true?
if you think 3 lbs is NOT heavy on things over stock tires,
take a 3 lb weight and hold it on the end of your fingers and then stick your arm out all the way and see how long you can hold it
its LIGHT at first but as time goes by, it gets heavier and heavier, then add in a tire that is Spinning and throwing that weight about, making it have more change to things due to momentum of the lbs
and you start to get more wear and tear on all parts of the atv
add in again, you have increased tire size 4-5 inches over stock tires, thats 20% larger, and more or less you lost 20% of the HP the ATV had
so if it had 30 HO to start with your now down to 24 hp
ain't NO one riding a STOCK Honda ATV that THINKS it has too much HP as is, or power period
honda's are known to have TOO little HP as to every other atv out there , WHY would you want to run on less HP
there is again NO way to change physic's
them 4-5 inch taller tires, ALTERED your stock gearing that is a FACT, no way around it
that then makes atv have LESS power to turn BIG tires
some folks drive a 4 cylinder and think it has ALL the power they need, some drive a BIG V 8 and think the same
does it make one wrong??
its all about what one feels is ENOUGH
the folks that REALLY run BIG tires on Honda ATv's and play right, DON"T run them on stock gearing, as they actually want to have GOOD use of there atv;'s
and do a GR to get back all the power they LOST going to taller tires!
its just science at work, and if your happy barely moving them big tires, then your HAPPY like that, MOST however are NOT
there are guys on atv's with twice the HP of a honda and NOT happy with ENOUGH power they have
HP is one of them things when on a TOY, you always want more NOT less! LOL your money spend it as you like
