It gets stuck and does not revert to the standard position. Does this have to do with the spring, or is there a different problem? (Pic shows it in stuck position)
I tried doing to light poking/prying with a screwdriver and it wouldn't budge. Should I be prying from the inside or outside of the drum cover?Circlip pliers for the circlip, you can buy a set of internal and externals off eBay for about $15.
The seal.... Usually seals are a use once item, it's probably worn out and will more than likely no good to reuse once you have it out. Best option is to order a new one, again it will be relatively cheap.
Edit: To remove the seal, pry it gently with a screwdriver or an awl, be sure not to damage the seat (area where the seal fits) when poking around with a screwdriver.
You can also screw a self tapping screw into the side of a seal and then attach vice grips and pull, usually the safest option if your in any doubt about slipping with an awl etc
you need a pair of snap ring pliers to get the snap ring out, and just tap the seal out from the inside outwards, that's how its done. make sure to have a new one on hand BEFORE you remove the old seal !.I tried doing to light poking/prying with a screwdriver and it wouldn't budge. Should I be prying from the inside or outside of the drum cover?Circlip pliers for the circlip, you can buy a set of internal and externals off eBay for about $15.
big rings like that are always installed in the inside of most rear brake drums.Hey guys, where does the ring clip go on this drum? The Partzilla diagram isn't very clear and it didnt even have one when I took the brakes apart (??). I put it on the outside, but I bet that isn't right. There is no obvious groove.
