1 - 18 of 18 Posts
ok so here is the deal: i have been posting threads and asking questions left and right so that i dont mess anything up and i think i have it just right except that i went to measure the space in between my 22in. stock tire and fender and found out that there wasnt that much room and even though i am getting a 2in. lift kit i dont think that it makes the sides of your fender wider (correct me if i am wrong) but i WAS planning on getting 25in. tires but i dont know about that now unless you guys can help?
Are you saying you don't have an additional 1.5" of space between the wheel and fender?
i have like 2.5 but i dont want the tire to scrub the fender
Are you talking about the height of the tire or the width? If you're talking about the width, you could get wheel spacers, if you're set on getting wide tires.
no im talkinbout the part of the fender that is in front and behind your feet, i measured it without lift and i dont think i have enough room for bigger tires . if i am wrong then just tell me
Oh yeah, I understand what you're talking about now. If you measured and you don't think you have enough room, then you probably don't. A lift isn't going to help much in that area.
Just put the lift kit on and get the stock height tires in the tread you want you should be fine then the lift kit isn't going to give you any more ground clearance on the differential or front end. btw
These do come in 22 X11-9 by the way and 22-7X11. $75.00 for the rear each and $55.00 for the front each
I think you can get Mudlites in those sizes too.
Discussion Starter · #18 ·
thanks guys carlisleso much for your hep and i think i am going to go for the bighorn 2.0 or the carlisle tires cause' they have tires close to my stock size and they have 12in. diameter so i can put itp wheels on so thanks guys!
1 - 18 of 18 Posts
