I have a 2007 250 Honda recon with electronic shift. I can't keep the atv on. i've use the choke on a cold start and does crank over then shuts off. I close the choke it cranks over stays on for a second or two then turn off. I've change the sparks plug, replace the gas with fresh one. fresh battery, clean filter. help anyone!
I sounds like you might have picked up some trash or water in the carb bowl?/ take it off ad clean it out spray some carb and choke cleaner up into the bottom of the carb if you don't remove it. you also might check for a cracked intake boot.\
Welcome to the forums!!
Try taking the fuel cap off and start it.I am also thinking a blocked tank vent.
