I got a 1994 honda fourtrax 300 4x4 that is in gear and can not put it in Neutral I’ve seen people start there’s in gear does any one know how to do that
Is your clutch locked up? Try adjusting it.
Is your shifter lever loose on the shift shaft splines? Splines stripped?
Download the service manual and check parts links in my signature block below
If you pull the wires off the neutral light switch and wire them together so the neutral light is on it will crank when ever you push the starter button.
Related Threads
Honda ATV Forum
618.3K posts
80.1K members
Since 2008
