Makes sense. I've never had one do it but have shied away from some brush kits that showed that in the reviews. LOLThe starter is spinning the wrong way and it has nothing to do with the brushes. The starter has front, middle, and rear sections. The middle section contains the permanent magnets. If you turned the middle section around end-for-end during reassembly, the polarity of the permanent magnets is reversed and the motor will spin the opposite way. You need to disassemble the motor and turn that middle section back around. Always mark the sections of a starter before disassembly so you will be sure to put it back together the same way it was.
The OP seemed to imply that the starter was engaging before taking it apart to install new brushes. If the one-way bearing was working before taking the starter apart, it will work after installing the new brushes too.and if it is spinning the right way ?, chances are, the one-way bearing is bad behind the flywheel.
agreed ^^^. if he did not put the starter back together wrong ?, and the starter is spinning the correct way ?, most times the one-way bearing goes out, and this would keep the motor from turning over. but I do agree with ya, if he put the starter back together wrong ?..well..you answered himThe OP seemed to imply that the starter was engaging before taking it apart to install new brushes. If the one-way bearing was working before taking the starter apart, it will work after installing the new brushes too.and if it is spinning the right way ?, chances are, the one-way bearing is bad behind the flywheel.
