I have a 1986 Fourtrax TRX200SX. I just got it back up and running after a family member gave it to me. It runs awesome. However, if you turn it off after riding, and its in Neutral, something continues to spin down for at least 10 seconds....I read online it could be the one way bearing. I cannot locate a means of testing this before disassembly and replacement. Also, in my manual it says to remove the right side Crankcase cover to make the repair....the noise I hear I swear is on the left side crank case pull starter area. I have no clue what it could be though. If you let it spin down and then put it in gear, the noise immediately stops. I have no issues with the starter or shifting. I'm wondering what it is.
I have the right side cover off to change oil and check filters. All is well there. You can only spin the clutch wheels in one direction. So...what is the noise Im hearing at shutdown?
