Hey all.
I am replacing the shift motor on my '03 Rancher. Thanks to the advice here, I have added a liberal amount of white lithium grease to the gears. I'm trying to reinstall the gears and I'm stuck on the spindle gear. In the manual, it shows to align the dot on the spindle gear with the "wide tooth on the shift spindle".
I don't actually see anything unique on the shift spindle except the flat spot, and that is NOT aligned in the manual picture. The (other) attached image of my unit doesn't show the underside, but is there actually a tooth on the bottom that is wider than the rest that is not shown?
Not sure how to proceed.
Thanks.
-g
Thanks.
-g
