Hey everybody im new to the forum. I have a 2001 Honda Rancher 350TE esp. My speedometer/odometer/trip is not working. It just registers 0 mph on the display and mileage doesnt add up. The hour meter works though. Can please help me out? Thanks
Welcome to the forums. Just a guess, but maybe your speed sensor is bad. I noticed that you had another post about shifting problems. Since the ES system needs input from the speed sensor to shift properly, maybe the speed sensor is responsible for both problems. Since the 2001 model doesn't store trouble codes, the only sure way to find the problem is to check each component. A service manual will show you how to check each component.
thanks man. I checked everything related to both problems. Im almost certain that both sensors are shot. I pulled out the angle sensor and it had a little bit of rust on the tip. And the speed sensor and grease and dirt on it.
i got lucky i took my speedo sensor out cleaned it off and tapped on it some and its working ..knock on wood.
had all the same symptoms as you guys did .
thanx for the tips
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
