Have a Boss Rebel sound tube that had a hum , so plan is to use the tube and change out the amp and speakers to run MP3 , the tube is well built and has a set oof tweeters in it that I am going to see how it sounds added in , the mounting bracket is something custom that I had built with diesel engine air filter housing mounting brackets , the original equipment in the tube appears to me to be Pyle , same covers and speaker built is similar , the original speakers have the amp built into the speaker
Hardest thing looks like a mount to secure the amp from flying around inside the tube and being able to get it in and together as this tube is glued shut , i seen a guy on you-tube that made a mount that folded up , slide in and then screwed together
