This is my first post on this board, and I'm sorry to be beating a dead horse but here goes. I've seen a number of post on here making reference to the solenoid clicking problem on Honda ATV's. I am having the same issue. However, mine is not doing it all the time like most of the others on the board.
Sometimes my 1999 300TRX will start fine by using the electric start. Then, all of a sudden, it will click at the solenoid thus causing me to use the kick start. Once I kick off the ATV, I can cut the key off and back on, which will allow the electric to work fine. After shutting the ATV off again, the solenoid will sometimes click and other times it will work fine.
I've not checked the battery power for the simple fact I've never had to charge the battery after the ATV has set for months thus making me think the battery is OK. It starts right up. I'm wondering if I may have a loose connection somewhere and the riding sometimes interrupts the connection causing it not to want to start, or I have a solenoid going bad. I've not checked the connections or terminals yet, but will do that this weekend. Is there any thing I should check besides the connections and battery before ordering a solenoid or do you guys think the solenoid is on it's way out?
This problem just started all at once and like mentioned, don't do it all the time. Any help or information is appreciated. Thanks
