1 - 12 of 12 Posts
tezzer , I would hook anything to that outlet after I seen what is possible by doing so , I bought a 300 not running for a parts bike, the grandfather had changed so many parts on the bike and could never get it to spark and gave up , while stripping all the wire loom and tape off the harness , I found the power wire to that plug had melted all the way back to the battery , after replacing the harness it cranked right up and that is now my son's 300 and a great running bike
if you want a power port , I like using those connectors , that look like a boat trailer light plug , except it is two wires instead of 4 , it is the same connector used on battery maintainers , so the battery maintainer plug can double as a power lead
It’s explained in your owner’s manual
I used mine to power a pair of led lights and an accessory plug-in.
It’s a switched circuit to be used to power accessories
i will check it out now
i will check the wires out now fingers crossed their not like that i picked it up couple of days ago runs great needs rear brakes tho ordered them yesterday the weekends job its been sitting for a couple of years i check the oil was ok jump started first time i'm well happy with it..
thanks for the warning about the wires
Here ya go this diagram is in the owner’s manual
and probably service manual too
This is the part you’re missing that hooks up to your accessory item
Take a volt meter (VDC) and hook up to the wires in your end. Switch off should be zero volts; switch on should be 12 vdc
I meant to say I would " not " in my post up above and forgot the not , wouldn't let me edit it
were you in advanced mode?, when you couldnt edit? i seem to have had the same problem on occasion, just ever so often.
Accessory plug
Side note: I would love to have that tank!!
Great idea
1 - 12 of 12 Posts
