1 - 12 of 12 Posts
05 Honda recon 250te
Rebuilt motor replaced cam chain and oil chain..
After the 30-45 minutes of riding my engine gets mega hot.i realize it smokes a bit because of the rebuilt oil o everything..but why is my engine getting so so mega hot..this model dose not have a fan so not sure how it cools ..
Any input would be great
If you did not get the rings spaced correctly it can cause this, or I had an old rancher that did the same thing and it was cause I had to light grade of oil, may also check for low oil?
Sent from my XT1609 using Tapatalk
The rings spaced correctly ? And I'm running 10w40 synthetic in it. Not low on oil..not sure what rings your talking about..I'm thinking maybe I dint line the oil pump chain shaft up right after replacing oil chain ?
And when I shut it off after running a while it sounds like a small jet powering down inside the crank case..lol. Like ruuummmmmmmmmm click...
There can be quite a handful of possible contributing factors to explain overheating... can you be more specific? Does the motor start, idle normally and make good power? Is it smoking? Compression normal? Valves adjusted right? What was replaced/remachined during the rebuild? OEM or aftermarket?
Hes talking about getting the rings end gaps correct. But that theory has been disproven. Your rings are spinning on the piston all the time in an direction they chose. As long as at first start you dont line every single gap up your fine. Because from there they go where ever. But sounds to me like an oil pump issue.(I know zero about that model engine) but a chain not on the teeth of a gear would make the noise your talking about. My .02
Full synthetic oil on a fresh rebuild. Rings will never seat and will burn oil. Clogged jets making it run hot?
I beg to differ, I run full synthetic in all my engine rebuilds, never, not once have I had the rings not seat ?, and burn oil ?, where ya come up with this info ?.
Reactions: misterclean59
Engine builders of all types, sizes, purposes, from stock motors to drag/circle track open classes racing... have for decades been pounding on the table about the customer/user/owner/racer putting synthetic oils in freshly built motors. Apparently the body of evidence against is overwhelming. I've heard and read most of the arguing points and found nothing to disagree with... but I've never give it a thought to put synthetics in any of the motors I've built anyway.
By the time my motors were ready to turn over to the owner or take to the track in our cars, I had already gone through several oil changes (three during the first hour of running!) preparing each of them, including all dyno and shakeout time. I would never put synthetic oil in a freshly built motor. Never made any sense. Isn't any better oil than a good racing oil in my mind. And since oil is changed out after every event, its cost prohibitive too.
The only motors I ever put synthetics in are daily driver grocery getters (exceptions: motors I use in sub-zero temps get synthetic oil too), only after at least 5000 miles has been logged on the clock, minimum. Synthetics can benefit cams and valvetrains providing more longevity and they usually have much a lower temp pour point, else I wouldn't ever buy it. Others won't leave home without it though... and I got no quarrel with that either... if something is working for you, it don't need fixing!
My biggest fear is that your oil pump isn't working. Say it isn't so... :)
Next on my mind are the piston clearance and piston rings gaps, assuming you changed the piston & ring set? Did you bore and hone the cylinder oversize? Or just hone it? Or not?
Is it a forging or OE type piston? Did you check the piston/bore clearance? Check ring gaps?
Is your oil cooler getting warm? If not, you are not pumping oil which means your pump chain probably derailed. Did you replace the tensioner?
Rick
1 - 12 of 12 Posts
