New to the ATV world and was wondering if it is a good idea to put Slime in new tires as a prevenative measure. I just bought two new TRX420FA's and will be doing some trail riding and was wondering if the Slime will help prevent flats. Thanks
trust us..yu'll thank us when you replace the tire !..lmfao...that stuff don't come off with a-jax and steal wool !..lmfao.Thanks, I was worried about the mess it would cause. Think I will just get a good plug kit.
lol fourtrax..i've use my truck to break the beads..now..thats ******* all the way !..lmfao.I've used it and had pretty good luck, it was messy when I took my tire off but the pressure washer cleaned the rim up just fine. I also have a plug kit for bigger problems for the minor issues I think it does okay. I've never tried to patch one.. hell I don't ever want to take another ATV tire off again as long as I live.. LMAO
LOL thats exactly what we did.. truck and a board.. but still couldn't break the back side loose. had to cut the tire off then pry the rest of the bead off. then put a whole in the rim.. then couldn't get the new tire to seat.. it was a real PITA but its all done and fixed now.lol fourtrax..i've use my truck to break the beads..now..thats ******* all the way !..lmfao.I've used it and had pretty good luck, it was messy when I took my tire off but the pressure washer cleaned the rim up just fine. I also have a plug kit for bigger problems for the minor issues I think it does okay. I've never tried to patch one.. hell I don't ever want to take another ATV tire off again as long as I live.. LMAO
i never use a board..just my front tire on my truck..lol..it takes some doing if the tire has been on the rim along time..but..with a spin of the tire..and back an forth..they will come off !!..oh..for future tire removal..not sure if anyone has done it..but..it sure makes it easier to ever get the tire off later down the road..before you mount your new tire..i take my rims ..and run them on a bench wire wheel..after that..i grease the rims on the bead..it sureeeee makes that tire come off easier later down the road !LOL thats exactly what we did.. truck and a board.. but still couldn't break the back side loose. had to cut the tire off then pry the rest of the bead off. then put a whole in the rim.. then couldn't get the new tire to seat.. it was a real PITA but its all done and fixed now.lol fourtrax..i've use my truck to break the beads..now..thats ******* all the way !..lmfao.I've used it and had pretty good luck, it was messy when I took my tire off but the pressure washer cleaned the rim up just fine. I also have a plug kit for bigger problems for the minor issues I think it does okay. I've never tried to patch one.. hell I don't ever want to take another ATV tire off again as long as I live.. LMAO
