21 - 40 of 43 Posts
92's muffler was straight back and didn't make the u-shape , but you can put a 88 muffler on a 92 , I have that 88 set up on my 92 -------- 91-94 were the years for Southern Blue and judging from the muffler and the plastics , I'd say that is a 91 ------------- the 10 digit of the vin would tell what the frame is , but parts could have been swopped around and it could be a collage of parts ----worth $150
this is a 92 with a 88 muffler , the original 92 muffler was straight ------ so if the muffler is correct on the bike you have a pic of , then it is pre-92 -----one thing bad now days on the 1st gen is they are getting harder to find parts for as there are parts that are unique to 1st gen ---- but that makes the parts on it worth more
I would jump on that one , that could be a project or a parts bike for the next 300 you find , I am presuming from your pics that is a 1st gen , the engine has 2 more HP and a 1,000 higher rpm range , the engine and wiring harness will go right on a 2nd gen frame , but be careful as it is very addictive
Discussion Starter #28
Well if it is still around when we get back from our trip I will probably go get it. I like doing this kind of projects, like a lot of you guys. Not just quads but bikes and other stuff.
Here is an example of an old Heald Hauler I did for a lady running a ranch for troubled youths. Her deceased husband first built it from a kit many years earlier and when he passed it just sat. I only charged her for parts (some of them anyway) and that was at her insistence. She ended up giving me a gift card to Home Depot for my work.
https://www.hondaatvforums.net/forums/attachment.php?attachmentid=128316&thumb=1
https://www.hondaatvforums.net/forums/attachment.php?attachmentid=128324&thumb=1
https://www.hondaatvforums.net/forums/attachment.php?attachmentid=128318&thumb=1
https://www.hondaatvforums.net/forums/attachment.php?attachmentid=128320&thumb=1
https://www.hondaatvforums.net/forums/attachment.php?attachmentid=128322&thumb=1
I wish my quads turned out this nice. These were kits from the 50's and 60's. Used a 10hp engine and centrifugal clutch with forward and reverse. Uses hand activated hydraulic brakes. Lines were so bad I replaced ll brake components. Thankfully there is an outfit back east that has new and used parts for them. They also had models with 4 wheels. Early version of UTV's I guess. The bed is a dump bed. Every part you see rusted was removed and power sanded by yours truly. A few had to be replaced but very few.
Discussion Starter #29
Buy it. The rear end would bring close to twice the asking price, if the rear end is good.
Then you find a 350D rear and have a free-ish bike!
Not only free-ish , it be better-ish
Obviously I am not the collector you guys are, so what is the difference in the two models?
One thing I did wonder about. The knuckles on my 86 TRX350 clunk pretty good when making sharp turns, and a search months ago turned up few solutions other than another used front end with no guarantee. I was wondering if anyone has ever grafted a newer 4wd front or a 2wd front end onto the TRX? I figure ANYTHING is doable, but not necessarily easy.
Ever hear of such a thing?
no way you can use a front differential from a trx300 in a 1986 trx350 fourtrax, completely two different atvs !!. the differentials are no where near made the same !!.
Discussion Starter #31
I get what you are saying, but really nothing is impossible. Whether or not it is worth it is another matter. Like I said it was just a thought.
When I have watched guys take the old Ford twin I beam front off a truck and give it independent coil spring suspension, then I know most anything is doable but might not be practical.
Now things like drive shaft on wrong side etc, those are game changers. Another thought is a 2wd front end on it too. Only if this one fails. Hey a neighbor of ours, when I was a kid, built his own tractor with a Ford inline 6 and back to back manual transmissions. It became a 3 speed tractor with 3 gear eatios. Everybody told him it would not work and would break from the torque. He used it for years to plow his 20 acre fields.
marlinman; Hey a neighbor of ours said:
Back in my days of 4wd truck mudding , some of my buddies were running "under drives " , which was a case that lowered the reduction and was mounted behind the tranny , I wanted to do it but never got around to it before 4wd trucking got out my system
Used front ends from the 350 foremans are cheap, but as you said, finding a good one is the trick. If your knuckles are clunking I would check bearings and your front axles. I doubt anything is wrong with the diff.
You like Marlins? I've always been a Winchester guy but the Marlin levers are nice.
the knuckles on old trx350's don't clunk, it's the cv joints, very common on those makes/models.
Discussion Starter #35
It probably is the CV joints. Seems a few months back when I first heard it, I did some research and IIRC there were none to be had.
Jeepwm69
Bearings are good, repacked those long time ago.
I do like Marlins, but funny thing, I have more Winchesters. Go figure! A gold centennial 66 in 30-30 and Model 94 Big Bore 375 Win, top eject. My Marlin is a stainless guide gun in 45-70. Thinking of having the centennial converted to a JES 38-55, just because. Mine is the 26" octagon barrel model, and as a collectors item it's almost worth as much as a standard model. The Cent' 66 was not much of a collectors model, gold plating or not. Figured I would put a tang sight on it and make it a long range gun.
Another vote to go pick it up, but again i am partial to the fourtrax 300. Parts alone are worth the asking price. Looks like the bike is mostly complete.
Well he took the ad down today so I guess I missed it.
did you really think it would still be there ??????..if so ?, i've got some beach front property in AZ to sell ya !..lol.
21 - 40 of 43 Posts
