Hey all! New to the forums. I just got a 2006 honda trx250te from my folks. I have 2 issues. The 1st is shifting problems. The electric shift will shift fine as long as im up shifting. The down shifting will not work on the electric side. It does however down shift if i do it manually with the wrench. Also, the whole time the atv shows 1st gear and neutral light are both on. So if im in 5th gear, 5th 1st and the neutral light are all on. Its not a transmission problem, so where do i start?
As for the other problem, ive got a little noise when it idles. Its a slight chatter. I had one do it before and my uncle adjusted some lifters or something and it fixed it, but im no mechanic so i dont know what it is. If given steps, i dont mind to attempt anything. I was going to upload the video of the noise, but i only see an option for pictures. How can i share with yall the sound its making? Thanks in advance!
