2016 rubicon with 3500 miles PS light came on and power steering quit. Then the engine light came on and the 4 wheel light started flashing. Will not shift above 1st gear reverse still works
There should be a tool in the tool kit that will let you manually shift. I think the shift motor is bound up somehow from that your saying, I'd take it off and check it. One modification, is to replace the stuff gummy grease with ALL TEMP White Lithium that will let it shift smoother.
Test the neutral switch.... That will cause it to have only first and reverse.
Sounds like you got some water somewhere its not supposed to be.... Causing all the electrical haywire.
2016 Rubicon with 4500 miles
Engine light comes on then turns off followed by two long flashes then three short flashes? Runs fine dosn't seem to have any other issues.
