Can anyone tell me what's going on with my Honda? It starts runs and goes but only in 1st gear will not shift only can go about 10mph or less..... Everything else seems to work fine and the gear lights on the cluster is flashing..... It doesn't matter of you use esp or automatic it doesn't change anything will not shift! Any advice would be greatly appreciated thank you in advance for any help you can give! Just want to make sure how much this thing will cost to fix if it's worth fixing at all.
The flashing gear light is morse code. You should read how many longs and shorts.
It does not shift gear because the computer has detected a problem. Fixing it can be fairly easy.
Discussion Starter #3
Thank you very much for your help! Where can I find code list to tell me what the flashes mean?
