Let the voting begin for the September 2018 Honda ATV of the Month! We will leave the poll open until the end of the month and then announce the winner. We got some really good pics this month, thanks to everyone that participated and GOOD LUCK!!
Rick66
2013 trx400x. Bone stock engine other than a slip on exhaust. Rear skid, nerf bars, front bumper, steering stem w/anti vibe mounts and protaper bars
Z7What
Custom Retrofitted 5000K HID Projectors With Amber LED Parking Lights - Dual 9” Single Row LED Light Bars - Badlands 2500lb Winch With 6000lb Synthetic Rope & Aluminum Fairlead - KFI Winch Mount - Dry Box Mounted On Fender
M_Quick
2008 Trx700xx AMR Reaper Custom Graphic Kit, Hidden Comfort Camo custom Seat Cover, Ehs Big 3, P/P head, Xcalibur Cam, Hard Welded Rockers, +1 In/Ex Valves, +3 Throttle body, 11:1 CP Piston, EHS Lid w/all vents, Uni Filter, L8ton 11/16th Sway Bar, PRM 0.160 Front A-Arm Guards, Desert II Front Bumper, Rear Utility Rack W/Dual S3 T-5500 Water/Dust Proof Case's, Honda Racing Nerf's & Full Skid Plate, Pro Taper Contour 1 1/8" Bars, Odi Lock on Grips, Precision Racing Shock & Vibe Handlebar Clamp, Mod Quad Billet Shifter, Rear Brake Delete, Throttle & Brake Cover Set. GBC Motorsports XC-Master Tires on OMF Performance Reinforced DWT 0.190 Wheels, Black Knight 14" LED Bar With Race Optics.
retro
"A Creamsicle Orange" 2000 Rancher ES 4x4 TRX350FE
Warn 2.5ci 2500 lbs winch on modified KFI mount
'05 Rancher 400AT Selectable 2WD/4WD front differential & driveshaft
'05 Rancher 400AT Master Cylinder w/switches & harness
'04 Rincon Selectable switch & throttle housing
'07 Rancher 420FM 4x4 Dash Indicator light
DIY Selectable Clutch Gizmo (2 regulators, adjustable clutch voltage)
Melatv's Start-In-Any-Gear mod
Oil temp sensor 100kΩ trimpot mod (adjustable cooling fan kick on)
25" Dirt Devil A/Ts
Motomudman
2004 Honda TRX400EX Lexx Exhaust CME air scoops and new air box with all that ugly battery crap in it! Motor is stock
