1 - 16 of 16 Posts
I have a 93 fourtrex 300 got a new battery and selenoid a couple months back and it has started fine here recently the selenoid has started clicking when you try to start it but if you kick the kick start once it will let it start with the electric start could it be the selenoid going out and sugesto
Hi
Usually when a solenoid is going, everything dims; it might click once. if it was chattering I’d say battery. You could swap solenoid out cheaply enough it’s probably worthwhile.
I would put the battery on a tender/ charger to see if it’s discharging due to a drain somewhere.
Then I would clean every connection with brass brush, emery cloth and vinegar. Uou might just have dirty connections snd maybe a starter needing rebuild
First question is.... Where did you buy your solenoid from, eBay, Amazon?? If so then it’s most likely a China cheapy solenoid and has failed on you. You need to buy OEM or known good brand, even a good used item from the likes of PSN (powersportsnation.com)
Reactions: Goober
Yea I got it off eBay
The bike was given to me and didn’t know what was wrong with it so just wanted to see if I could get running cheap I got it about 2 months ago
I was thinking cause it was a cheap selenoid that was the problem cause the batter is fine it’s the recommended battery
Yes it is working after I kickstart it so is it the selenoid
@Goober is right, could be a battery with a cell down however, could be solenoid combined with a bad battery. Charge your battery and try cranking the motor, test the battery before and after, report back with readings.
Reactions: Goober and _Wilson_
what kind of battery did ya get? i.e. brand, or place of purchase, some batteries are better than others.
You'll need to replace any china parts that are on it, before expecting it to work as it should. Start right there... get that china solenoid off of it, then if it still acts up check the battery, starter, and charging system.
Hi , the parts you have replaced are most likely fine, what the problem is the starter motor brushes are worn out. You can get after market starter brush sets,however if you use genuine brushes(they are not that dear) they will last the best by a long shot. I would also get the starter motor rebuilt by a good mechanic ( again it is not an expensive undertaking), but he (or She) will know things to look for which can save you money in the long run . Cheers from NZ
what do the brushes look like?, on the starter.
1 - 16 of 16 Posts
