Pulling my engine (see other thread) - down to the step of removing the rear driveshaft & it should pop right out.
I'm following what's described in the attached picture; however, only thing that's came loose so far is the wrong end! The end that goes into the diff popped out easily (unintentionally spilling gear oil all over my garage floor too, mind you) - but "not" the intended end nearest the engine. I can't get this joint to budge at all - advice?
