1 - 12 of 12 Posts
Question, how often do you need this extra weight ? If alot/all the time, I'd go with bolt wheel weights OR last choice would be fluid in the tires, sand bags are going weigh in on every part of you suspension wheel bearing swing arm bearing, hub spilnes, all your front suspension upper n lower ball joints tie rod ends etc
Naw it's fine, for plowing snow ? ( Short term ? ) Yeah sand bags , and I'd be sure to check the tire pressure all the way around , get the best tire foot print you can :)
Reactions: XplicitRacing6
I like mud lite tires, i run at's at the moment, when. I Upgrade ill go ether with the new mud lites OR mud lite xl, BUT here in TN we dont see that much deep snow, and hardly any ice, n I'm SURE. Some others will chime in on tires , LOL
1 - 12 of 12 Posts
