I get backlash when I try to start my bike. I think it has something to do with the timing chain. Can those be adjusted? And how? I can't find my manual... Thanks in advance for the help.
sounds to be out of time
You need to pull the very top off the motor. Your cam will be exposed. You then need to remove the chain(DO NOT LET IT FALL INTO THE CASE) There are marks on the sprocket the chain rides and the cam holder. You have to line those up and then put the chain back on. Make sure the piston is TDC when you do this. There are other steps invloved like the chain tensioner and stuff. I highly recommend trying to either find your manual or buy a new one. You can probably find a PDF manual online for pretty cheap.
If it's jumped time chances are you have a bad gear and a stretched chain.. did someone tear down your quad and put it back together incorrectly?
Welcome to the forum.
