Sure. The manual will probably tell you to run them at 3.5. My tires say 7 max running, 15 max to seal bead, and the manual says 3.5. I had them at 7 and it was bounching around like hitting a ballon in the air, so I lowered them to 5 and it's much better. 3.5 would probably be fine, but I haven't been back out to test that pressure.
Agreed^^^^ just don't go too low you will get sidewall rollout but I run about 4.5 to 5 in mine when Im playing in softer terrain.
On my sport quad, I run 4psi all around when i trail ride and 7psi when i race. In my Rhino I run 12PSI in the Terracrosses but when I go to the sand i drop them to 3.5psi
