1 - 1 of 1 Posts
RT250ST-B
APPROVAL:EEC
Engine Type:Single Cylinder, 4 Stroke, Water Cooling, Manual Clutch, with Reverse
BorexStroke:70x64
Compression Ratio:10.0:1
Displacement:246ml
Max Power:11.5 kw/(7500±5%) rpm
Max.Torqu:18.7 n.m/(5000±5%) rpm
Fuel Tank Capacity:12 L
Gear 5 Forward Gears And 1 Reverse Gear
Transmission Mode:Chain
Start Mode:Electric
Max.Speed:90 km/h
Ignition Mode:CDI
Battery Capacity:12v9Ah
Engine Oil:1 L
Lubrication:press Splash
Parking Trig:Mechanic Lock
Chassis
Untitled
Min.Ground Clearance:100 mm
Front Tires:AT22x7-10
Rear Tires:AT22x10-10
Front Brake:Disc
Bear Brake:Disc
Front Suspension:Independent Double A-arm
Rear Suspension:Swing Arm, Mono Shock
Product Dimensions:1690x1100x1130 mm
Wheelbase:1180 mm
Seat Height:900 mm
Dry Weight:167 kg
Load Capacity:180 kg
Climbing Ability:bigger than 25 degree
Min.Turning Radius:2000 mm
Number of Rider 1
Others
Color:Red, Blue, White, Yellow
QTY of 20'/40'/40HQ' container: 12/28/42 units
1 - 1 of 1 Posts
