alright here is my problem. at the right rpm my engine sounds like it is not getting enough gas (sputters and coughs). it doesn't occur in neutral when i rev the engine up slow or in first gear only in 2 gear around the 29 mph and in 3 gear around the 47-50 mph range and it wont go any fast then 50 mph. the quad worked fin till the cam chain broke and i changed all the damaged parts. my thought are that my timing may be off 1 tooth but just what to get some other opinions on the problem before i start to rip the cylinder head off again. any opinions will be great thanks
what YR ? I would check the basics filter in the tank, good gas, clean air filter , hows the spark plug. I never been inside a 650 "guessing from your name" but if you just replace all that stuff its possible you could be off.
yes the bike is a 650 and it is a 2003. i already changed the spark plug its brand new. the filter was cleaned like 3-4 weeks ago but i will clean it agian. the gas is good. but i never even considered the filter in the gas tank it could have some shit on it. thanks for the idea i will check it first then go for a ride. a friend also suggested that i may have some shit in my carb any thought on that??
could be see alot of stuff come threw the shop with crap in the carb.
