on the handle bar ?..or lower engine ?..and what trouble is it giving you ?my 300ex has reverse and im having troubles with the reverse sensor/safety switch is there anyway to bypass it or not ?
first off..if i'm understanding you right..your playing around with your reverse and nuetral wires with a test light...lol..now..here's the answer to your problem..you got a short..or it's loose at the reverse switch on the lower engine case..and maybe even your neutral wire is lose also..check to make sure they are free from dirt.oil..and tight..and they aren't shorting out anywhere on your frame and engine..check this first.i think both what its doing is every so often it wont start so one day i took the test light to the wires coming from the handle going into the motor case as soon as it touched the wire i hit the button and it fired right up i shut it back off and took the wire tester off hit the button again and nothing every so often it just thinks its in reverse theres been a few times when ill be in any forward gear and it hits a rev limiter at about 1/4-1/2 throttle just like it would in reverse id take it to get it fixed but it would cost me around $200 because the shops "have to check the problem"
