yeah..its just not worth it to mess up the tranny like that..no way will I ever do it. mine is a manual shift...and I still will never over-ride the safety lock out for which they were made for.Don’t do it; too easy to tear up the tranny.
All Honda ATVs that I know of use this design–yes the ES ergonomics makes it more difficult to use. It’s not a huge problem but shifting while wearing really thick gloves is a bigger pain.
I have an 02 Forman 450es and was wondering if there is a way to bypass the the little red button to make it easier to shift into reverse
I can't say for a footshift model, because I haven't been able to ride one myself in over 16 years, but for ES, and I've been on a few.....they don't even let you shift down into Neutral until you are basically at a dead stop. I've done the reverse override on our Recon ES and I can't even get it to go into neutral, let alone reverse, if I try while moving forward. So maybe ours and the other ones I've been on are weird?Don’t do it; too easy to tear up the tranny.
All Honda ATVs that I know of use this design—yes the ES ergonomics makes it more difficult to use. It’s not a huge problem but shifting while wearing really thick gloves is a bigger pain.
So here’s what could happen if you fixed the reverse lever: you’re rolling down a hill, you grab the brake levers and start down shifting. You’re pushing the down button, pass neutral and BAM you’re in reverse.
it may have something to do with the speed sensors ?. if I had to guess ?, this is why you have to come to a complete stop.I have an 02 Forman 450es and was wondering if there is a way to bypass the the little red button to make it easier to shift into reverseI can't say for a footshift model, because I haven't been able to ride one myself in over 16 years, but for ES, and I've been on a few.....they don't even let you shift down into Neutral until you are basically at a dead stop. I've done the reverse override on our Recon ES and I can't even get it to go into neutral, let alone reverse, if I try while moving forward. So maybe ours and the other ones I've been on are weird?Don’t do it; too easy to tear up the tranny.
That would be my guess too. And seems to be a bit of a built-in "fail-safe" for the ES models at least, which is what the OP has. I guess if I were @mossboss I would try it out and see if it even allows him to shift into N while moving. My bet would be on it won't even let him do it. Easy to go back if it does let it go into N while moving.it may have something to do with the speed sensors ?. if I had to guess ?, this is why you have to come to a complete stop.I have an 02 Forman 450es and was wondering if there is a way to bypass the the little red button to make it easier to shift into reverseI can't say for a footshift model, because I haven't been able to ride one myself in over 16 years, but for ES, and I've been on a few.....they don't even let you shift down into Neutral until you are basically at a dead stop. I've done the reverse override on our Recon ES and I can't even get it to go into neutral, let alone reverse, if I try while moving forward. So maybe ours and the other ones I've been on are weird?Don’t do it; too easy to tear up the tranny.
Fish are all four gear reduced ? Just making notes... Actually.... That would a be handy option... If carefully used....I am a fan of reverse lock out by-pass , it is a pain in the butt , especially when you ride tight trails , I have 4 that are by-passed right now , 2 300's and 2 450's , I don't let ANYONE ride any of those 4 bikes but me , have never shifted it into reverse while rolling forward yet , but I guess it only takes one time yet
Unlike
Unlike
without a GR , on a manual shift model ?, yes..you can and will tear the tranny up, electric shifts and GR's would keep you from dropping too many gears at full speed.Okay.... Let me try it this way..... Is there more of a chance of damage to a stock geared machine, compared to a 54% gear reduction machine, IF a rider accidentally shifted to reverse, while rolling forward slowly (say about the speed man can walk)
I've never ridden or even delt with a gear reduction machine, so..... Just curious as to what damage could happen ?
hmmm..maybe I can answer that last part fish ?. a GR only controls the output of the clutch to the tranny, in other words, it slows the tranny down, or in this case, the drive shaft/drive line. it has nothing to do with the rpms as far as I know ?, your engine is only going to put out so many rpms as the piston/fuel, and all that will allow, it still has to transfer to the drive line..correct ?, you can put out 10k rpms ( yes..thats a thrown out number...lol. ) but doesn't the GR change the transfer to the change clutch, then tranny ?. maybe I am thinking backwards on this ?, but i'm just spit-balling this...lol.The way I look at it , with gear reduction your chances of causing damage from going from forward to reverse is just as bad or even worst than without gear reduction , cause it is really about the RPMs , with gear reduction you can achieve higher rpm's faster than without it ---so why would it be any less a chance of causing damage
it can be done..but not very wise !!. if your not slow enough to keep from going all the way down into reverse from a forward motion ?, can ya guess what will happen when you down shift all the way into reverse from going forward ?, can ya say '' got money '' ?!!..lol. cause..thats what your gonna need to replace all those tranny gears if your not slow enough ?!. but to answer your question, just adjust the lock down nut if there is one ?..which I don't think that model has them ?, your stuck with tying the reverse lever back at all times, BE WARNED !!!..IF YOU DO THIS ?, YOUR GOING TO TEAR SOMETHING UP IF YOU FORGET TO SLOW WAYYYYYYYYY DOWN !..LOL.
