Look for this in Youtube, its a pretty good video. Your wire may not be Gray, so may have to meter it to see which one is the reverse wire. hondaboats reverse lightHello have a 2022 Rubicon 520 dct n looking for wiring diagram or info on where I can tap into to trip a relay to turn on a light when shift into reverse.. not wanting to use a switch to turn it on.. thanks in advance
Yep good video n I checked with volt meter and None of them are grounded only in reverse.. I asked hondaboats about it too but no reply yetLook for this in Youtube, its a pretty good video. Your wire may not be Gray, so may have to meter it to see which one is the reverse wire. hondaboats reverse light
There can be two ways either to consult to the motorcycle tuner or watch you tube motorcycle tutorials. Second way would be effective if you have a bit idea regarding motorcycle denting or its fixing.Hello have a 2022 Rubicon 520 dct n looking for wiring diagram or info on where I can tap into to trip a relay to turn on a light when shift into reverse.. not wanting to use a switch to turn it on.. thanks in advance
